gwinmo
I am looking for a place to buy carb parts. I have a 550 oliver with a tsx 811 carb it has broken brass valve ( adjusting needle?) at the rear of the carb above the drain plug. Were could I locate it. No carb kit I have found has it. thanks for any and all help. gary
Where are you located? Kent down in Texas will probably have a used carb. V. E. Petersen in Moline OHIO (in Toledo area) is probably the largest Carb parts dealer in the eastern U. S. There are also other carburetor/parts suppliers.
It's the main Jet
I found one at a swap meet was a John Deere part as they also used MS carbs and just a little larger than I needed but it worked
I also got one at the AGCO dealer 8 years ago
I am in need of one if you find a good part number/supplier
