super99
The seal on the front of the transmission or PTO on the 1963 550 has been leaking bad since before I got it and the grease tube for the PTO clutch is leaking but they kept on greasing it. What a mess!!! I scrapped a coffee can full of grease, oil and mud out of it and it still needs washed out. I sprayed some brake clean on the clutch to try to find the set screw to remove and it was put together with the set screw underneath the pin that you push in to adjust the clutch. It looks like the rear main seal is leaking and there is oil under the front crank seal. Also leaks oil out the rear around the PTO shaft. I took the pressure plate and clutch disc out to make room, the clutch is black like it has oil on it. Odd thing, I have run a 6' Bush Hog on it and the PTO and the engine clutch doesn't slip. This might turn into a long drawn out affair!!!
