574 plow width
Anonymous-0
got a 574 want to run a ford 102 two bottom 16 inch rollover plow. has 16.9 30 on rear what is the best wheel spacing. whats the biggest plow anyones every pulled with a 574. i have a book for the plow but it says different spacing for different ford tractors.
574 should play with 2x16.
Roll over plow has to be centered on the tractor so regardless left or right side plowing the width of cut is the same. Only ran a roll over plow very briefly "for fun". Seems to me the best way to get the wheel spacing is hitch the plow on, adjust the plow/3pt to be dead center then set the wheel spacing so both the left and right wheels will run in the furrow and allow for the 16" cut for the first bottom. Hope you have bar axles....
