TractorDad3
Greetings and thanks in advance for your thoughts.
American Bosch injection pump. Electric fuel pump nowadays. Working through some older diesel fuel I suppose (2-4 yrs old). In the winter I plug it in for nearly an hour where the block is hotter than the hottest summer day by the time I fire it. Preheaters work. Approx. 3000 hrs on original tach. Follow the owners manual on starting and maintenance procedure.
I have noticed that I am cranking longer and longer before she starts. My question is, can timing change, over time? While she only has 34 hours since rebuilt pump, changed fuel filters and timing checked to be on point (fired up immediately then), I am noticing this longer cranking period now. Ill check and see where its at and maybe advance it a bit further than last time unless one would suggest otherwise.
Just want to know if I should add adjustment to my yearly PM list.
