590 (1979 2wd)
jacob morris
hi guys,
my 590 has a very nasty crunching noise coming from inside around the crank pulley area, it only does it if hydraulics are pumping, any ideas- it sounds expensive
thanks in advance
jake
Hi Jake,
First thought is that you have a problem in the engine balance unit. This is mounted towards the front of the engine and attached at the level of the sump (oil pan) face. MF insist that the balancer drive and driven shafts,needle roller bearings,keys and oil pump gears must be changed after 5000 hours work. Is your tractor anywhere near or past this figure? Sounds like it may be a damaged gear or collapsed needle bearing.
The sump can be removed without removing the engine. The balancer unit is heavy so support it on a jack or similar. Timing at removal is not important but it will need to be timed on refitment.
The first step would be to remove the sump and inspect all parts unless you can isolate the noise to the timing cover.
DavidP,South Wales
I have seen quite a few MF 590s do over 5000 hours and not have a spanner on the engine , so why do MF recommend changing the balancer unit at 5000 hours .
thanks for quick reply,i will have a look asap, is this the kind of job i could do with the aid of a manual or am i better off taking it to a dealer, is the timing an easy task?
thanks
jake
Hello Jacob,
The removal and refitment should be OK with the help of a good manual but MF recommend the use of a 50 ton press and suitable tooling to press the needle bearings in. In all probability you will not need anything like 50 tons. I am quoting from the MF 500 series manual. I would suggest that if you plan to keep the tractor that you invest in a genuine MF manual for the 500 Series. They are available on ebay. The difference in cost is well worth it. MF say to remove the timing case cove for reassembly and turn the engine to TDC. It is necessary to align the mark on the crank gear with the two on the balancer. I believe that these can be seen from underneath but not 100 % certain.
A balancer repair kit is available from Tracpieces/Bepco which contains the shafts,bearings,bushes and keys and should be in the region of £70 or $90 Bepco number 30/92-3. MF number B1243. Also required one gear 30/94-6 (31164582 or 746694M1) approx £30 or $42. Finally a hub 30/99-1 (33451801 0r 734905M2)approx £30 or $42.
If you take it to an MF dealer the parts are likely to cost a lot more. If you have an independant repairer who has access to non gen parts then that would be cheaper.
Before we go too far down this road we need to establish the source of the problem for certain.
David P
Hello Huw,
I can't give you a definite answer to your question other than playing safe. The balancer shafts are rotating at twice crankshaft speed in needle bearings and therefore do not have the endurance of ball bearings. Also although reasonably wide the balance gears are small in diameter and are therefore likely to wear especially with the loads generated by each semi-circular balance weight setting up vibrations to counteract the natural 'two up, two down' effect of the engine.
Cheers
DavidP
thanks again for your prompt and detailed reply!i am working away til thurs but hope to get stuck in on friday, i just hope the problem is easily identifiable,thanks again and i will keep you posted
jake
Hello Jacob,
I have never seen a 590 is hyd pump drive off the front of the engine ? If the balancer was bad i would think it would make noise all the time. when those balancers go bad they make some really scary noises.
Good Luck Ed
abcrepairparts
hi, basically a noise started coming from the front of the tractor just under the power steering pump, we drained the oil and refilled it and the noise went away until we switched the hyd. from loader to 3 point linkage the noise then came back, now it is constant, hope this clears things up
thanks
jake
Hi Jake,
I can't seem to find a 590 listed in my engine parts. what model engine is it ? I think I can get you a bal rebuild kit pretty cheap. before you remove it, if you pull the Valve cover and turn the engine over till you get #4 valves rocking (one closing and one opening) that should be TDC #1 then look at the bal, the weights should be down. when you unbolt it it shouldn't move, when installing it spin the bal and let it stop turning the weights will put it in time.
Good Luck Ed
aqbcrepairparts
thanks for the reply, unfortunately its made my head spin! i have ordered a book and on friday i will take the sump off and have a look. From that point onwards i will probably be relying on yourself and DavidP,South Wales to help me out!
thanks again,
jake
hi,
i stripped it down and found that one of the the balance weight bearings had collapsed, my problem is the 3 grub screws which hold the balance gear to the weight have sheared- elongating the holes in the process, i have searched bepco etc but no-one seems to stock the weights in the uk, what are my options guys?
thanks
jake
hi,
thanks
jake
