6 volt positive ground battery charging
mwkellner
My Dad"s Super c battery has been sitting for over a year. I want to charge it or determine that the battery is no longer any good. I have seveal questions that I need answered here because I have gotten conflicting opinions from friends, neighbors and O"Rielly"s auto store. Do I hook up the charger + to + or backwards? Do I need to disconnect the battery from tractor before charging? What polarity is the generator on the tractor charging the battery? The tractor is kept on another property and not run very often. I would like to keep this from happening in the future. Is a cheap float charger effective in this situation, or do i need the more expensive digital mantainence charger. I know this is a lot of questions, but I know they will be answered correctly here. Thanks so much for all of your help.
Pos or neg ground make absolutely no difference in charging. ALWAYS pos terminal of charger to pos terminal of battery and neg to neg!
As posted below + to + and - to - from charger to battery
Battery can stay in and connected to tractor when charging
The tractor originally was Pos ground meaning its Pos terminal was frame grounded. The charger so long as its + to + and - to - charges the battery correctly
To be safe and once the battery is charged, Id Polarize the genny prior to starting the tractor.
John T
You will be using a 6 volt charger, of course.
Finding a float charger that outputs 6v can be a challenge.
--->Paul
Thanks so much for your replies. I will charge it and see if it comes back to life. I doubt it will. Should I use 2 amp or 10 amp?
As others have stated always when charging (or Jumping) any vehicle always hook + to +, and - to -.
If a vehicle is positive ground or negative ground, that only means how the battery is hooked up to the vehicle. It does not change the polarity of the battery. On many shematics we were taught to believe ground is negative. On vehicles, ground only means the wire leading to the vehicle's frame.
When jumping or charging a battery when you hook negative to positive you will double the voltage of the system and can destroy all the electrical components on that vehicle or both vehicles more so when jumping. When you hook a battery charger up positive to negative you will get lot of arcing and the charger doesn't even have to be plugged in for this to happen.
We have several JD's with 6v positive grounds. From experience, disconnect the cables from the battery to the tractor, then connect positive to positive and negative to negative on the battery and charger. Trying to charge the battery without disconnecting the batter cables from the tractor will be unpleasant. BTDT
Your advice makes no sense.
The battery explosions you alude to occurred because somebody jumpered chassis to chassis instead of - to - and + to+ .
I don't understand that post either, I charge my farmall 6 volt right in the tractor, +to+ -to- never had any problems, why did they use positive ground back then?
Connect the charger exactly as you do with any other item. + to + and - to -. The only thing that no one else has mentioned is that when you jump start an item with reversed polarity is that you do not want the vehicles to touch. I charge mine with a 10 amp automatic charger. It does very well for me. I bought my 6 volt battery new in Sept of 2008, been going strong ever since.
Forget how it is ground makes no difference as to what side of the battery is ground because you ALWAYS hook a charger up + to + and - to - NO MATTER what. The term + or - ground is one of those things to many people over think which is what you have done
(quoted from post at 10:51:33 11/26/12) You will be using a 6 volt charger, of course.
--->Paul
The two Shumaker float chargers I have will automatically detect if the battery is a 6 volt or a 12 volt and set itself accordingly. I am using one on a 1940 H with original 6 volt cut-out relay, positive ground system, and an identical charger on a 1940 M with 12 volt alternator conversion. The charger just doesn't care one way or the other.
I never said there was an explosion. Hooked + to + and - to - with the battery cables attached. The digital display on the battery charger went nuts, beepers went off, etc. Tried removing one cable, still got the warning. Disconnected both cables and no problems.
I've been hooking up battery chargers 30+ years, so I'm not a novice. I've never had a battery explode and I never had that issue until I tried to charge a 6v with positive ground and didn't disconnect the cables.
(quoted from post at 13:19:56 11/26/12) I don't understand that post either, I charge my farmall 6 volt right in the tractor, +to+ -to- never had any problems, why did they use positive ground back then?
I believe the idea was that the electricity "flowed better" with a positive ground.
"Common knowledge" is that electricity flows from positive to negative. Science says it flows from negative to positive, because the electrons do the work, and electrons are negatively charged.
Reality is, it doesn't make a hill of beans worth of difference. It doesn't flow perceptibly/measurably better one way or the other.
Negative ground was likely chosen because it is easier to remember. Negative (with regards to numbers) is generally regarded as "lower". Ground (with regards to the dirt under your feet) is also considered "lower."
general motors trucks believed in negative to positive
flow so much in the 40's and 50's that they made
their pickup trucks negative hot. they believed
with 6 volt cranking it gave a stronger cranking.
one of their thoughts why gmcs were better than
chevrolet.
Your problem did not come from the fact the battery cables where still hooked up but came from the fact digital equipment is so much more sensitive to stray voltage as in stack etc that it messes the reading up. Learned that when I was a Navy E.T. and worked on stuff they was so sensitive you had to hook your body to ground to keep from blowing the circuits up
If it is dead a slow charge is more likely to bring it back then a fast charge will. Make sure all 3 cells are full of water before you start charging it also
For maintenance I put small solar chargers on batteries that are not used in winter. They do not completely make up for loss but are a lot better than nothing and very low cost.
Nancy, I have also had this same problem with my JD40. Have to disconnect the positive ground from the battery, otherwise the charger gets very angry. I don't understand why.
I've never had a problem charging batteries while their cables are still connected to the tractor (truck car etc.). 6 or 12 volt, pos or neg ground, I've got them all. The one charger has a polarity indicator light that will come on green if you are connected right.
Seems to me most of the older stuff was positive ground. Ford flathead cars and trucks, Cockshutt, Case, JD tractors from the fifties and earlier were all positive ground.
I have seen where people hook chargers up backwards to a completely dead battery and it will charge backwards. Then you have a mislabeled battery that you should drain dead and charge correctly!
It's always amazed me how much response this topic gets over and over all year long! I think we've covered it all pretty well this time.
i was told the reason for positive ground on 6v was to reduce sleeve pitting in the water jacket.
Nancy
Have to jump in here on your side. Before anyone gets excited, stay with me. Have worked with many systems, 6, 12, 24 volt, pos & neg ground. Even Mack 12v with rev-pol solenoid that feeds 24 to starter, 12 to everything else, & 24v bus that has 1 post in the big panel (post #55) that is 12v for accessories.
The problem that I have run across is that some chargers have the metal case connected to the neg cable.
No big deal unless the case of the charger makes contact with the vehicle chassis that is connected to pos post of the battery. Then the fireworks begin. Seems to work okay if charger is not allowed to touch metal on vehicle.
Willie
You've pointed out something that is just damned interesting, to me. So Chevrolet had negative ground throughout their line, and yet GMC chose positive ground fot their trucks,same as Ford. When did GMC go negative ground? '56, '57?
not sure when but the advent of modern transistors in the radio is probably the reason gmc and others went to positive hot. prior to transistors, radios utilized a vibrating tube which would operate either neg. or pos. ground. modern transistors will operate one way typically pos. hot, neg. ground and since most vehicles of the era were wired so, gmc changed to positive hot.
I never ever charge more than one battery at a time with the same charger.
One battery, in the battery compartment of the tractor. Battery charger was on the wood floor, so no conductivity between the charger and the tractor.
No one questioned anyone's expertise, so just chill out.
I spoke from firsthand experience. I know for a fact that if I hook my battery charger to a positive ground tractor with the battery cables still attached, things do not go well.
Since the charger was sitting on a wood floor and not contacting any metal, that had nothing to do with it, either.
What happens to you, B&D, if you connect a charger to a positive ground tractor and not disconnect the cables may be completely different.
You do it any way you want, but before I put a charger on a positive ground tractor, those cables are coming off. Period.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/library/" target="_blank">
Willrogers.jpg" border="0" alt="Photobucket"
</a> Will Rogers once said <big>[i:654c4848f0]"There are three kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves."[/i:654c4848f0]</big>
AFIK, on 6v cars & light/medium trucks, Chev was always neg gnd, GMC & Pontiac were pos gnd, not sure, but think rest of GM line,Buick, Olds, Cad, along with Studebaker, Hudson, Nash etc & complete lines from Ford & Chrysler were pos gnd.
When GM changed to 12v in 55, they made everything neg gnd, Ford & Chrysler did the same in 56, IHC trucks went 12v pos gnd in 57, neg gnd in 58.
Don't know about the others, but Henry Ford went pos gnd because his buddy Edison said to, claimed it helped prevent corrosion of steel frames.
With the invention of the transistor in 47 things start moving quickly. Early diodes required that the metal case had to be on the neg side, so that was connected to chassis. Other choice would be to use 2 wire isolated circuits instead of using the chassis for one side. Most builders went neg gnd with 12v to be ready when transistor radios & diode controlled alternators that were in developement hit production.
Kind of O T, Edison invented a lot of stuff, but was working with D C current for powering buildings for lites etc. His system powered lower Manhatten, but could only push current about a mile, too much loss from conductor resistance. D C current will not go through a transformer to increase voltage for long transmission lines, then back down for consumer use. His rival, Tesla, was working with A C. His first system from Niagara Falls to Buffalo used A C, transformers kicked up to high voltage for less resistance & line loss, than back down for consumer use. Proved A C current could be sent over long distances.
Longer than I wanted to get,& more info than you wanted.
Willie
