600 ford points
Pull the distributor cap with out unhooking any of the plug wires. Carefully the rotor then the spring clip that is under the rotor DO NOT loss that clip. Pull the dust cover. From there you should be able to see how it is done. You set them at a gap of 0.025 when the distributor lobe is on the high point. But that said your better off buying a I-T manual so you can look at it hard to explain on here.
