600 Hydraulic Pump
OK_BobL
Have a 1955 660 with piston type hydraulic pump. I need to replace the orings in the manifold to stop leak on rear where it ties into the intake line.
When I take the manifold off, will the hydraulic sump try to drain from the low pressure line from the sump? I"m sure I"ll get some draining of the lines but don"t know if the fluid will try to drain out of the sump or not.
Thanks for the information in advance.
Bob
Thanks, Wayne. I didn't know how it was plumbed into the sump. At least now I can plan an approach and not be too surprised.
Bob
It would be a great time to change your hydraulic oil, and get rid of the moisture and other impurities that are probably in it, unless it has been changed fairly recently.
If your manifold is machined to use square cut O rings rather than normal round O rings, it would be worth your while to hunt up the proper square cut rings. One local NH dealer only had the round ones, and they said they would work OK. I could never get them to stop leaking for any length of time, and had the manifold (and of course, the hydraulic oil) out several times. Finally I went to a dealer 40 miles away and got the square cut O rings. No more leaking.
When you get everything back together and the hydraulic oil filled up, you will probably need to prime the hydraulic pump. There should be a pipe plug at the top front of the hydraulic pump. With the plug removed, use the starter to turn the engine over about 10 revolutions, with the coil wire removed from the coil to prevent the tractor from starting. There should be some oil coming out of the hole the pipe plug came from. When the oil no longer has much bubbles of air, the pump is primed. Quit turning the engine over, replace and tighten the pipe plug and replace the coil wire. If your pump is working properly, the system should work. It is a little messy, but I don't know any way to do it any easier. Good luck!
