610-B shifting problems
Racoon
Hello, I just registered on this site, the information on here looks awesome. I just purchased a Case 610-B, and when I shift to high with the shuttle shift it seems like it goes into neutral. Thinking it may be low on oil, but I don't know how much oil the transmission holds or what type of oil it takes,,, (I think ATF) Any suggestions or comments would be appreciated. Thanks
Welcome to the forum. Your 611 is a case o matic Tractor,
and has a different shifting characteristic than direct drive
tractors. First I might suggest that you give John Saeli a call
and get an operators manual for that tractor. This will help
answer many many questions you will have in the future. In
the meantime we will try to answer as many as we can for
you. His number is 315-585-9826. The pic below shows
where you can read the case somatic reservoir level. It
holds roughly 4 gallons of SAE number 10 weight motor
oil(MS-DG). That is the alternate oil you can use, and
automatic transmission fluid type A Its preferred. The
dipstick should read overfilled on the dipstick by about 2
inches when cold. You also have a filter upfront in front of
the Radiator on your left Facing the front of the tractor.The
case filter part number is G13113, and you may wish to
purchase two , And use the other one which is located on
the right hand side of the tractor just below the battery.
That is your hydraulic filter. Please include a picture of the
old gal once they give you picture taking privileges. Once
again welcome to the forum Chuck machinist
Racoon, not sure what you mean by Shuttle Shift as the 611B never had that feature, If you are referring to the lever on the opposite side from the throttle lever that is the Direct Drive lockup lever, on the first cover back from the steering column support there is a cover with a Hi/Low range lever, Please clarify what you were referring to in your original post, thank you. Chuck and some others have these tractors in various stages of renovation so will be able to assist you.
Chuck, that smoking is going to stunt your growth!
Racoon, original Case filter element part number G13113 is an edge wound cleanable element. Originally serviced by cleaning with gas, you can substitute something saver if you want, I use mineral spirits as that is what I have in the parts cleaner.
Joe
