Welcome to the forum. Your 611 is a case o matic Tractor,
and has a different shifting characteristic than direct drive
tractors. First I might suggest that you give John Saeli a call
and get an operators manual for that tractor. This will help
answer many many questions you will have in the future. In
the meantime we will try to answer as many as we can for
you. His number is 315-585-9826. The pic below shows
where you can read the case somatic reservoir level. It
holds roughly 4 gallons of SAE number 10 weight motor
oil(MS-DG). That is the alternate oil you can use, and
automatic transmission fluid type A Its preferred. The
dipstick should read overfilled on the dipstick by about 2
inches when cold. You also have a filter upfront in front of
the Radiator on your left Facing the front of the tractor.The
case filter part number is G13113, and you may wish to
purchase two , And use the other one which is located on
the right hand side of the tractor just below the battery.
That is your hydraulic filter. Please include a picture of the
old gal once they give you picture taking privileges. Once
again welcome to the forum Chuck machinist
