Rusty.Staples
Hello all, new member here. I just came across this site and I could really use some help. I just picked up a '62 JD Wheel INDUSTRIAL (SN 4010 25T58417)
I actually ran it about 10yrs ago but the owner took it home and let her sit. Needless to say, I cant get it to run. I put in new filters and a lift pump, bled the air out to the IP but I can't get any fuel out of the steel lines. I did remove the IP correctly after lining up the marks. I removed the side cover and the fuel shut off was stuck. I got it moving freely now. Re-assembled but still no fuel out to the steel lines.
It looks like he tried to start it but gave up a few yrs back. I'm thinking he removed the top of the IP. Should the "C" on the rotor be facing up or down? The "C" was up when I opened it up.
Looking down from the top, the pump turns counter clockwise. Looking through the side cover window it rotates from left to right. Roosa Master DBG VC 631---4AF
Are these old tractors Positive or negative ground?
I have to get this tractor moved to my property ASAP.
I do need a SM2045 manual. I'm confident I can tear it down, inspect, mic, clean and re-seal and reassemble. But I'm not sure where I should look for the best parts and upgrades because of the ultra low sulfur fuel. So many cheap parts out there these days. If I have to tear it apart, I would rather buy whatever it takes to do it right and as quick as possible.
I thank you in advance
Rusty
This post was edited by Rusty.Staples on 01/19/2022 at 10:21 pm.
Rusty
