630 deisel wonder
I have pulled my 630 from the pines and have been working on getting it running. It came from a farm that did not know what maintence was. Well short story short have the engine completely taken apart. All exhaust and one intake push rods are bent after hitting hard on the pistons, but nothing else is wrong, no broken cam, no stuck valves, actually looks like motor had been overhauled in 89' (date on rod bearings) very very little wear to none. Any ideas as to why the push rods are bent? Someone try to much ether once? appreciate anyones input, thanks in advance
looked better sitting in the pines......just foolin
Does it have a rain cap? maybe it got water in it and when the tried to start it the rods got bent. It could then have blown out the water and not rusted the sleeeves. Not to likely I know, but...
The cam marks and crank marks were in line, sat in shed for 20 years in it's current condition, the valves hit the pistons so I expected a broken cam, but cam is not broke.
(quoted from post at 18:13:55 12/23/11) I have pulled my 630 from the pines and have been working on getting it running. It came from a farm that did not know what maintence was. Well short story short have the engine completely taken apart. All exhaust and one intake push rods are bent after hitting hard on the pistons, but nothing else is wrong, no broken cam, no stuck valves, actually looks like motor had been overhauled in 89' (date on rod bearings) very very little wear to none. Any ideas as to why the push rods are bent? Someone try to much ether once? appreciate anyones input, thanks in advance
Check the camshaft key, it would not be the first I have had to replace. A thorough cleaning and drying with brakeclean and some 271 loctite will help make up for a little damage to the shaft and gear if present. mEl
I believe on that engine the rods need to be facing a certain way. That could be part of it. You also might want to check and make sure the head wasn't shaved a bunch or aftermarket pistons added.
To check valve timing, put #1 on TDC, #4 I&E valves should be overlapped evenly.(E valve coming up and I valve going down same distance)If they don't, crank or cam gear key is is sheared.
Just speculating: stuck valves? The push rods bent breaking the valves free while opening them, the valves did not close on their own & the pistons knocked them part-way closed again?
Do you have any compression?
