A few questions about doing a rebuild on my 630 power steering pump. I think the oil seals on my power steering pump are starting to fail as I am seeing some oil below and buildup on the pump. I have been looking at the SM2050 manual and watching a couple youtube videos for pointers. I would like to gather some input from the folks here.
It is probably safe to assume that I need to unbolt the radiator and move it as far forward as possible because of the tight clearance?
A shop press is recommended to be able to compress the fan spring to get the two little retainers off. I don't have immediate access to a shop press, so I was wondering if there are other options that folks have used to remove and reinstall the little retainers?
Once the pump housing is separated from the fan, it seems like a pretty straightforward process in removing and replacing seals, bearing, and maybe bushings, assuming there is no other wear or damage found in the housing, or am I underestimating this?
Thanks for any input!
