For those that don"t know yet, I"m a tractor newbie so be kind.
My 640 apparently has a bent PTO. I"m not sure if it"s the whole shaft, or just the "end" (sorry, don"t know the name of the piece you attach stuff to). It"s bent a good half inch+ off center. Unfortunately I can figure out how it happened. All I know is I attached my mowing deck to it and as soon as I engaged the PTO, the mowing deck drive shaft went crazy due to the PTO whirling instead of spinning on center.
Is this a handymans job? Could it be just a faulty PTO "end"?
I"m sure you all are going to say "pull the whole shaft and find out", but I guees I just need to hear it before I get the nerve to tear it apart.
I bought a PTO clutch awhile back. I took off the old PTO end to find out the new clutch wouldn"t fit into the the tractors" PTO fitting. (the bottom rim of the new clutch was ever-so too tall to make it fit to the shaft pin hole)
I"ll run it without a clutch on the shaft to see if the shaft spins on center. But gosh, why doesn"t that new PTO clutch fit down into there?
