grandpa Love
I'm sure the answer is here somewhere but after the update I can't find how to search archives. Ford 640. Replaced cam follower pin and adjusted the lift a couple months ago. It worked great for a couple weeks. Now it will lift smooth with a light implement, but anything heavy it has issues. With heavy implements it won't lift at all until you pull lever all the way up past the stop. Then it will lift until it almost hits the fenders. If you move lever down at all it slams implement to the ground. Worst is the tedder-rake, 950 lbs and sometimes wont lift at all unless you push the little draft lever down. Not down and locked , just move it a quarter way down and then it will lift. But when you let off it drifts down quickly. Really hard to cut and rake hay. Fluid is full. Could the new cam follower pin fall out?? Thanks for any help. Using the tractor today on a fence job in the boonies so I won't have cell service until later this afternoon. Hopefully yall can come up with a fix for me! Got several days of nice weather starting tomorrow and need to cut hay with the sickle mower. Narrow gates at new field and haybine won't fit.
