641 ford wokmaster
Anonymous-0
3 point lift will lift without load, but will not with a load (plow).It has a piston hydraulic pump. Where do i place a pressure gauge to check output of pump? Can I place it in the plug at hydraulic pump or in the bottom plug of hydraulic housing. There is oil coming out of this plug at pump when tractor is running because we have tried bleeding any air in system.
theres a relief valve just in front of the lift cover that screws into trans housing...it could be stuck open or your lift piston rings are shot.
