Anonymous-0
I have yet another question about a hydraulic problem on my JD 6410. I have had problems out of the new pump where the stall out pressure would not exceed about 2000 psi. I found that I had a bad O-ring in the loader valve of the valve stack which was throwing my sensing off. Got that fixed and now the pressures are correct. The problem now is that when I stall the system out at max pressure then release the SCV or whatever, the pressure slowly drops back down to the 450-500 psi standby range. I don't believe I had this problem before I replaced the O-ring, but I am not 100% certain. I really don't know what should be checked next. Any help would be greatly appreciated.
