Greenpower
Picked up a 656 believe a 1967. Has a loader on it and would like to hear from others that have the same set up. I believe there has to a better way of running the hydraulics. All they did was plug into a rear remote that feeds a valve bank bolted to the fender. In order to run the loader you need to bungee cord the #1 hyd lever that feeds the back to get hyd flow. Can’t a person plumb this directly and use existing leavers on the machine?
I have had a pair of 656/2250 loaders set up using the bungee cord method for 20 and 25 years. If I'm baling that takes higher engine RPMs, I take the bungee cord off. No problems for the lower RPMs when loading or feeding. A lot simpler and cheaper than trying to find a power beyond adapter.
Can you expand on the power beyond adapter you speak of?
Never seen or had a power beyond, but.. A plate that bolts to the end of the valve stack to run the loader/implement without tieing up the remote circuits. Google it. Looks like they start around $500, plus the needed plumbing. Bungee cord is a lot less.
