6620 john deere
Anonymous-0
HI guys,looking for any ideas on a problem that I am stumped on. Been getting the 6620 ready for wheat today and I cannot get the reel lift cylinders to go down and the variable speed feederhouse will not slow back down either. Man ive checked everything, the tips match up, If i crack the tip the reel drops so theres no blockage there, took apart the valve and cleaned those poppets in there. Strange thing is I can hear the hydraulics "scream" ,if you will, when I push lever forward. I also adjusted the linkage. The feeder house goes down so theres no blockage from valve body back to the resevoir. I have a technical manual and theres no trouble shooting for this problem. Sorry for the long winded post but Im stumped, thought maybe someone on this forum may have seen this before and could save me a call to the dealer. Thanks for reading.
Take the quick-coupler end off the combine-side of the reel hose and briefly push the lever forward. if it still screams hook it back up and take the hose off the variable speed and try it again. All I'm going for here is to see where the oil is trying to go and maybe that will offer some clues. Fritz
Remove the coupler end and replace it. They will go bad and not let oil flow. Not that uncommon of a problem. I have had several over the years do it.
Hey JD I'm not familiar with 6620s. I'm confused as to why the relief valve would scream while lowering the reel. Aren't they gravity drop, or is there something else plumbed into that circuit. Fritz
The control valve that raises and lowers the real is a double acting one. The reel lift cylinder are single acting ones. So when you are using only the one hose for the reel lift the other side is dead heading with pressure as long as you hold the lever. It is usually not an issue because you are activating the valve just a few seconds at a time. This same valve works the varible speed feeder house when using a corn head.
