I have a 67 3020 gas w/4575 hrs with a Marvel Shebler carb with the slanted right side when facing it. I've read on this forum they're junk but mine seems to run fairly well but not as well as my 2510 gas. The tractor smokes and uses oil, hard to start in cold weather, is a real gas guzzler, has yet to foul a plug(new 8 hrs ago) but they get VERY dirty with black soot with in less than 10 hours. Today I did a compression check and all four cylinders were 110 psi but # 3 was 108 psi. Manual says 160 psi is the starting point. Are the problems with the carb? Would a new Zenith carb be a solution to most of the issues? If so, who sells the best choice. We only use the tractor 10- 20 hrs yearly. Oil is cheaper than an overhaul considering the use it gets. Should I replace the carburetor? I know they're not cheap. Thanks for any suggestions.
