Lynn Patrick
I usually hang around the Ford sites, but my son recently purchased a 674 gasser on an auction. We want to give it a much needed tune up, but are having trouble finding the correct numbers. The local parts store sold us the wrong plugs & rotor & I'm not real sure about the points. I looked at the tune up kit on this site & it lists spark plugs the same size as are in the tractor now (D18Y Champs), but then says the kit is for tractors w/screw-held distributor caps. His dist cap has the spring clips, & the cap does not seem to fit correctly. It also shows a dust cover that looks like an upside-down bowl & his is flat. Does it have the wrong dist? Or are the parts some previous owner put on the wrong ones?
Also, is the firing order 1234?
Thanks in advance!
Thanks in advance!
