Ok so I am about done with the 4020 and before I put the ROPS and canopy on I need to fix an issue with the 3point lift. When I got the tractor the right side rockshaft cover was already off and the previous owner handed me a new cable for it when I bought the tractor, there was no cable on it at all. They did not have the entire rockshaft block off that I can tell because I had to clear a metric ton of crud out between it and the seat thanks to a 40 year old rag stuck in there. I purchased the missing pieces of the cable, clamp etc and am working to get it moving like my 3020 does.
Here is what it does.
In the D Position - Must move lever almost all the way to the top to get it to move. And when it does it just goes about 1/4 to 1/3 up then stops. I cannot set it in position it goes to that one spot and that is it. My cable is maxed out on how short it can be. (Note if I remove the cable from the linkage back there I can rotate the lever more and it works as I think it should be carefully moving the lever to different spots to keep from smashing my fingers)
LD and L position - Move lever about to the 1 - 1.5 ish mark (i have no sticker) It goes all the way up pretty quickly.
I have the JD service manual and it says I can do this on the tractor without removing that whole block there. I understand for the most part what I need to do. I am trying to walk my self through it before I do.
Here is an image of how the linkage all looks inside with the dash lever all the way in the DOWN position thanks to my handy dandy inspection camera. Based on the image which way do I need to skip? Forward or back. I am thinking that I need to skip about 2 or 3 teeth.
