7000 planter
Does anyone know or does has anyone have any information on the insecticide applicators on a 7000 cornplanter, if you can put a little fertilizer through these.I was just wondering if you could. The one I have is liquid and wanted to put a little dry fertilizer by the seed to get it started and then add liquid nitrogen later. Just wondering? Thanks
Those meters in the insecticide boxes are designed for small granules.
Unless you find some ground up fertilizer I don't think it will work. Besides most dry fert. is high in salt and will burn the roots if dumped to close to the seedling.
Did you say you have liquid starter on the planter?
You can get low salt liquid starters that can be applied right in the row. You may have to reconfigure your injection part of the liquid lines to dump in furrow.
Talk to your local fertilizer supplier they should have some ideas for you.
Gary
I agree with Gary, I don't think you will be happy with the result. As a former dry fertilizer user and now liquid, I would never go back.
Ok I was just wondering. I spread fertilizer last year but this year I am going to no till some in and was just wondering. I did not use my liquid fertilizer. I guess I am going to make sure it works. Thanks
A lot of people used to put mini MAP through the insecticide boxes. Doesn't seem to be done as much as it used to. We have two liquid systems on ours, put 5-6 gallons of starter down with the seed and 32% UAN 8" away from the row.
And besides the other limitations, the insecticide meters are calibrated to put out a fraction of a pound up to maybe a couple pounds maximum per acre. That's not enough fertilizer to bother with.
I set my 7000 up to use liquid from my three point sprayer with coulters up front. Last time I planted corn, I put down 60 pounds of N per acre off 2 inches from the seed row. Worked great.
Gerald J.
You intent to "put a little dry fert. with the seed" is a great way....to kill the seed. Fertilizers are a salt, liquid or dry, and you need to keep fert. about 2" away and down from the seed. As the roots start to grow down they will find the fert, fert too close kills the seeds as soon as they try to germinate.
I once saw a hobby farmer apply 200 lbs of starter per A. and he made sure it "got with the seed". It did. He had a live plant here, one over there, another one out that way, another one way over there and maybe another one way, way out there....those were the survivors.
Use your liquid setup, and make sure you know where the fert. is going and how much is going there.
not to hijack this thread, but Gerald, do you no till? i always wondered if the smaller bar for the fertilizer colters would stand up in no till
I used to use a similar setup on several hundred acres of no-till with no problem. I did put a brace on between the small bar and the main bar that was made by Yetter. Lee
Gerald, is there any possibility you could post more pics of your planter set up. Are the coulters robbed off an old plow? I located an older plateless 7000 and was considering buying it to make a decent planter out of it. It has no fertlizer set up , but I have a 150 gallon and a 75 gallon poly tanks, that I thought I could use for liquid fert. I have to check, I may not need starter with the application of my chicken poop. I still want to get a planter and set it up for notill. My IH 456 has about seen it's better days and I have found the ol gal isnt very good at all even in min tilled seedbed. She needs to find a new home.
Dave, In sw MN we have planted corn into soybean stubble with a 7000, you should have some row cleaners, finger type like yetters or Martins work good and some banded fert. is beneficial if you have plenty of manure I would band some 7-21-7 or 10-34-0 with the seed, make sure the planter has down pressure springs on the parallel linkage, coulters shouldn't be needed except in corn stalks. A 7000 will plant int just about anything except an asphalt road with virtually no modications. We farm clay and silty clay loam soils, not sand. 7000 will be a big improvement from your 456
I have a couple more pictures, one more distant though that includes the tractor and this one that shows more details on the left side. Others I've not uploaded to a public server.
The coulters are from an Allis Chalmers 2000 Monobeam plow. I designed the mounts and the arms for the ammonia knives. I bought the ammonia knives from Heartland Agri Supply near here. They are only 3/8" thick so just about fit in the slit made by the coulter. Not much soil disturbance there but that gets the 32% down in the ground right away. And the slit gets closed as the main opener disks spread the seed trench.
dsc00120.jpg"
The trash whippers are an essential part to notilling. The coulters also cut the stalks so the trash whippers can spread them easily. And that way the stalks don't get hairpinned by the seed disk openers.
Gerald J.
Interesting set-up. I assume you are running the coulters to the side of the row, not directly in front of the row cleaners? I have the wavy coulter for my White 5100, wondering if I could make the same kind of setup. Do you use a sprayer pump to supply fertilizer to the coulters? Chris
Yes, the coulters are 2-1/4" away from the row.
And that mess on the back of the tractor is my sprayer. There's on orifice in the line to each ammonia knife to regulate the flow, so pressure and ground speed are critical. But that planter is so little load to the MF-135 that keeping a constant ground speed is easy. The sprayer has a good pressure gauge, a needle valve to return excess and a pressure regulator that doesn't do much. It uses a 4.5 gpm electric diaphragm pump that draws about 10 amps at 12 volts.
You probably could use the same setup, with the wavy coulters, but I don't like wavy coulters. I don't especially want to work the ground and if its the least damp, my neighbors that have run wavy "notill" coulters have found them to just turn into wads of mud. And this dirt worked wet turns into concrete.
On my setup, the coulters have two jobs. One is to make a slit for the fertilizer knife when planting corn and the other is to cut the straw or stalks so the trash whippers can separate it cleanly. That second concept came from Ray at Dawn, the maker of my trash whippers. The coulter is not there to till a seed bed, the notill ground is already mellow, it needs no tillage.
Gerald J.
