I started looking for new head bolts for this tractor and learned they are expensive. On top of being expensive ($160 to $240) a couple of the kits mentioned the long bolts are actually to long and one included an extra hard thick washer and the other supplier advised you to find said washer.
I came across a thread on a website talking about this issue and they advised buying Caterpillar head bolts
9S1374 - list $5.10 each, 1D4574 - list $3.84 each
They also advised buying Caterpillar parts - not after market Cat parts.
Anyone used these bolts in a 282? They are a lot cheaper and they are original Caterpillar parts - for what that is worth.
I would rather use Cat parts than after market IH parts from China.
SPECIFICATIONS FOR PART NUMBER 9S-1374
Thread: Coarse Thread UNC
Hole Thread Pitch: 13
Grip Length - 2 (in): 6.50
Head Width - 5 (in): 0.75
Grade: 8
Head Height - 4 (in): 0.39
Finish: Phosphate and Oil Coated
Total Bolt Length - 3 (in): 8
Thread Size (in - TPI) (in): 1/2-13
Bolt Length (in): 8
Head Height (in): 0.39
Grip Length (in): 6.5
Drive (in): 3/4
Bolt Type: Hex Head Bolt
Material: Steel
Material Description: SAE J429 Grade 8. Head Marking - 6 radial lines (150 ksi Ultimate Tensile Strength)
Coating: Zinc Phosphate + Oil
SPECIFICATIONS FOR PART NUMBER 1D-4574
Grade: 8
Total Bolt Length - 3 (in): 6
Grip Length - 2 (in): 4.75
Bolt Length (in): 6
Grip Length (in): 4.75
Drive (in): 3/4
Material: Steel
Grade: 8
Bolt Length (in): 8
Drive (in): 3/4
Material: Steel
Grade: 8
Bolt Length (in): 6
Drive (in): 3/4
Material: Steel
