FusionFarmer
I recently purchased what I believe to be an early model Farmall 706 Gas wide front, when I picked it up, it ran perfectly, everything was good, I saw and drove it myself, so I know for sure.
1.5hour trip home, and it picked up some electrical gremlins on the way. It will run decent when cold, but after about 10
Minutes or so, will develop a miss, and then start to surge and die. Wait 10 minutes, it will run a couple minutes and miss and surge and die, with some white/grey smoke coming out of the exhaust. This also never happened when I test drove it. When I test the battery, with the key off, I’m getting 12.5v, with the engine running at 1/4 throttle, I’m still getting 12.5v, I did notice a wire on the external resistor that is only hanging on by a strand or two, which may be my charging problem, but what about the surging/misfire problem?
