715 verses 95...
The 715 along with the 403 were probably the smallest 4row machines that IH ever built. So I would say the 95 would have more capacity. At the time the 715 was built they also built the 615, 815 and 915.
The 715 had a 22"x39" cylinder and 82 HP with a 70bu grain tank.It was built from 1970 or so through 79.
The 95 was built in the 60's. I can't find any specs on the 95
Gary
posted this before thought a few may have missed it cnt
I have run them both, and can tell you that a diesel 715 will out work a 95 of any power source. Nothing wrong with a 95, but a 715 will just eat more grain and cover more ground, and save grain at higher capacity, too.
No,just curious.But if a newer,low hour,diesel hydro came along for a "nickel",I'd think hard....
I will agree with you- the 715 compares to a Gleaner F, 95 would have more capacity. 55 would be closer to the F.
we had a 715, neighbor had a 95 both handled 4rw corn heads nicely, our 715 burned 4 gph, the 95 burned 7gph, if I remember the 715 held 83bu and the 301 engine was 100hp at the flywheel
First of all there are different hp ratings for the 715 depending on type of engine. The hp was either 95 or 107 depending on gas or diesel. The 95 will have different hp ratings depending on the year. I assume for this one we are using the squareback 95s so those would be 90 hp. Seperation area for the 715 is 5,289 and cleaning area is 3,089. Seperation area for the 95 is 5,600 and cleaning area is 4,691. Useable cylinder width for the 715 is 37 3/16". I say "useable" because the cylinder width on a 715 is actually 39 3/16" but the cylinder sticks out past the seperator on both sides. Cylinder width for the 95 is 40". Looks to me like both combines are on par. In fact the 95 trumps the 715 in every way except hp.
