I have this 2000 that starts and runs ok, but pops and misses on any speed increase. I replaced the points, sap, rotor, plugs, condenser, timing set at about 3 degrees btc. I also cleaned the carb, but did not have a kit to do it properly. The carb is a zenith, with no numbers on it that i can find. Just Zenith stamped in. 3 cyl engine. I ordered a carb kit and removed the carb again while waiting on the kit. I do not understand how the carb works. i understand basic carburetion and have been an outboard engine tech for 50 years. I'd like to know the function of the diaphragm assembly on the bottom of the carb and how it works as well as the proper assembly of it as well as the rest of the carb if possible. i have searched google and you tube but cant seem to find anything showing that bottom part of the carb bowl. Any suggestions? Thanks
