Anonymous-0
I recently purchased a 720 Diesel ES and I'm having a couple of issues with it. First off, when I had it delivered, it seemed to run real well and everything seemed to be in good order. After a few days, I noticed it smoking a little more than I thought it should. It was mainly white but would have a slight blue tint every once in a while. It smoked slightly at idle but it would belch smoke when I throttled it up. I thought maybe it had a little gunk buildup from sitting for a while. The gentlemen I bought it from hadn't used it very much. After putting some load on it, the smoking seemed to increase. Someone on the farm here used it to pull some wagons and he said it spat oil up through the exhaust and some blue smoke was coming up. After I tried it out, I didn't get any more oil but it still is smoking pretty good. I brought it into the shop and decided to investigate. I took the injectors out and cleaned them out. I also noticed that the oil pressure was up too high, so I tried to adjust the pressure, but the regulator will only turn so far out and it seems to jam and the pressure didn't change much when I adjusted it. I did an oil change and cleaned the air filter out, but its still smoking some. Does anybody have any other thoughts. My next thought was the injectors need to be throughly serviced as well as the pumps, but that doesn't really explain the oil. The smoke does have a slight blue tint to it sometimes, otherwise its white. Does it just need to be run hard to clen it out a little bit from sitting. I don't know the history of the tractor that well, but the previous owner seemed to have not used it very much. Can anybody shed some light on the next best move. I would like to get the tractor running well cause I wanted to use it this fall. The good thing is it starts real easy, but one other issue is that it dies when the throttle is pulled back, even before the stop knob is out. Is that just a simple adjustment. I bled the filters to see if they were clogged. they seem alright. Sorry for the long message but I want to try to explain the problem so I can get the most accurate advice as to how to remedy it.
