I have a 73 Ford 4000 3cyl gas and I m having hydraulic issues. When the tractor is cold i can barely lift my 3 point arms and when I have a disc hooked up to my rear remotes that will barely pick as well. Their is a whining noise sounds like it’s coming from my pump. Now when the tractor is hot I have no hydraulic pressure, my 3 point arms won t come back up I can t pick the disc through by remotes. Also the pto will not work either. When I shut the tractor off and wait 5-10 minutes I can get the disc out of the ground but takes forever to lift then quits working again. Any input would be much appreciated, thanks.
This post was edited by 3cyl4000 on 05/17/2023 at 11:51 am.
