730D crank play
TomW
I am having fits with a 730 Diesel with a taperlok flywheel. Can't keep it on the tractor. Replaced both thrust washers, twice but still not having any luck keeping the darn flywheel tight. I would appreciate any suggestions on this beast. Otherwise does anyone need 730 parts?
Thanks
I have a 730D that tore up the factory flywheel and I replaced it with a used taper-lock. Mine came loose also. I got a new hub and with it the directions for installing it.
I had no luck setting the end play the way the JD book says by bucking the opposite end of the crank and driving it on. I drilled a hole in the end of the crank about an inch and a half deep and tapped it 1/2"-20. I cut a piece of pipe that had a larger ID than the OD of the crank and used a thick flat plate with a hole in it for a 1/2-20 bolt and pushed the flywheel on the last bit to set the end play. That way I could work the clutch a few times and recheck the end play and readjust if needed before tightening the flywheel bolt. When I had it where I wanted it I tightened the flywheel then pulled off the homemade pusher sleeve.
It has to be tightened with a big wrench not with a hammer. I made a square wrench about five feet long from flat stock and box tube. Block the flywheel with a piece of angle iron, one end in a ring gear tooth the other end on the floor. I worried about breaking a tooth off the ring gear but that didn't happen. Tighten then whack the flywheel at the perifery with a big hammer in the "on the tractor" direction. Tighten again and repeat with the BFH on the opposite side of the flywheel. Repeat over and over until you can't tighten it any more. Mine has since held, though I have checked it a couple of times.
Hope this helps.
TomW
Taper-loc flywheels are made and sold by Allen Machine Works, 100 Fairview Circle, Jonesborough, TN 37659. Phone 423-753-5738. Ask for Dave - he builds them and would be a good person to talk to about your problem.
As posted above the directions from taper loc say hit it with a 16 lb sledge and tighten it, then do it again, and again till you can't tighten it any more. End play is important also. The books says .010 I think, check to make sure as end play will actually work a flywheel off.
If I had a tapped whole in my crankshaft I would put a bolt in the end to make darn sure it would not work off. Good luck I am doing one on the same tractor right now also.
I don't think there is enough room for the bolt with the flywheel cover on. At any rate tightening it the right way the second time has worked for me.
I have a 730D with 3/16" end play and a coke can stuffed in the flywheel splines. Flywheel would amazingly not come off, so I said screw it.
It's bad enough to look at it.
Well I have determined that the splines on my shaft are crap. Even with the taper hub I the best I can do leaves .005 inches of play in the spline so I am looking to get the crank resplined. While I have the beast apart what other parts should I replace? I am trying to go low budget here as I had to rebuilt the transmission a couple of years ago. Or would I be better off parting it out? Looking at my options to have a working haying tractor.
Thanks,
Tom
