730D differential
warren (il.)
Hi I am changing all the bearings in my 730D trans, diff, & rear axle.I found matel fileings in the oil.When i took the bearings off the diff and bevel spur gears off i found where the fileing came from. The shaft and gears all gouged up. Sooo my question is what is the best route to go? Look for a good used diff or a machine shop? THANKS Any ideas will be a big help. thanks again
I would look for a good used differential
I just did a 720D trans replaced all the bearings however the sliding shaft bearing part no. JD 8556 is no longer made by anyone. I had to go with the replacement and make a spacer sleeve
