730D question
LDP
I just bought a JD 730 diesel electric start that has too much oil in crankcase and I started to look for the source of fuel entering. I took off the injector pump cover and started it up and saw what looked like thin oil coming from the back of the injector pumps where the rods go to the camshaft. Both injector pumps had oil coming out there, one side more than the other. Is this normal? Up front where the injector lines are I didn"t see any leaks.
How long has it been since the pumps were overhauled? It's been a long time since I watched them operate but I don't think diesel should come out the back of them.
Don't forget to check the seals on the transfer pump. When they go that will put a lot of fuel into the crankcase. I had a 720 with that problem and when I unscrewed and pulled the dipstick a fountain of oil/diesel came out.
yes that is normal - the oil that you are seeing is lubericateing the pump. if you look at a parts bool you will see that a oil tube with o-ring fittings provides oil from the engine block passage to the injection pump bracket. no need for $$$$$ pump rebuild at this time i would say.
Many times fuel gets into the crankcase by way of the transfer pump. The seals get hard then the fuel leaks past. If this is the problem you can remove the pump and likley see that fuel has been oozing out on the inside.
I've also seen the threads on the bleed valve leak (valve that looks like a big hex nut coming out the top of the rack cover).
On my 730 the passage ways to the intake port were plugged so the fuel from the bleed off tubes was going into the crankcase. All I did was remove the tubes and blow out the passages with compressed air. Might be worth a look for you.
Thanks for the replys. Thanks to greendiesel for confirming what I thought I was seeing. And Scott 730 for you sujestion.I looked at those tubes and they look like they go into the head, but I could not see any fitting on the other end. Do they just stick in the head? If I do remove them, is it OK to just shoot air up in the holes where the tubes come out from? Thanks.
Correct, the tubes just stick into the holes in the head. I removed the tubes and shot air into the holes in the head.
