Follow the governor linkage down to the left side of the block. There is a set screw under a dust cover. Loosen the jamb nut and back out the screw. It lets the rack travel a bit farther at full load for a bit more power and much more smoke.
You just have to knock it out and replace with a new one... Your local Deere dealer can fix you right up.
It has been my experience that more fuel doesnt really do anything except make smoke. You may want to make sure that your old oil bath breather is not plugged from years of dirt and grime.
Most pullers use a dry filter element.
