Not being able to post a PDF file with the index, here's a cut and paste that I hope can be copied. Anybody want to improve it in any way, please do. And after paste it in this reply, it's not a neat as the PDF file. And a second thought, it you'd like to e mail me at
[email protected], I'll be glad to send you the PDF file. Thanks again for the replies. Spencer
SUBJECT TIP NUMBER
12 volt conversion 30
3 point lift arm balls - orintation 62
Battery - testing 49
Battery cable 41
Battery charger - hook up, tips 60
Brake drum screws - removal 54
Brake pswls 55
Brake shoes 17
Brake widget - 9N/2N 22
Brakes - parking 48
Bush hog - setting height 57
Carb elbow 56
Clutch - depress when starting 29
Compression gauge - how to use 46
Cooling system - thermostat 25
Cotter key - hole for 51
Disbributor coil 33
Distributor - bushings 68
Distributor point screws 37
Distributor points burned 38
Draft control lever - location, setting 58
Drawbar - hitching to 19
Dust Seals - front wheels 2
Engine - attaching to bell housing 59
Engine oil weight 6
Engine serial number 71
Exhaust leak 53
Exhaust pipe clamp 8
Fan belt sizes 75
Fan shroud 35
Firing order 72
Fuel - adding lead 5
Fuel screens - locations 45
Fuel sedimnet bowl 70
Fuel shut off valve 9
Fuel valvel 21
Gas filter 15
Generator - polarize 23
Genertor -three brush 20
Governor - bolt 1
Governor - checklist 14
Hood - how to remove 12
Hydraulic fluid - amount 4
Hydraulic fluid - changing 3
Hydraulic lift piston part number 63
Hydraulic pump safety value 44
Ignition points - making them last 67
Ignition points - quality of 66
Jumpstart 43
Lift arm problems 16
Lube tips 32
Mantenance frequency 40
Manual 39
Multi meter - how to use 47
Oil filter part number 64
Oil pan plug stuck 65
Over Running Coupler 18
PTO - estimate speed of 69
Pulling a tiller 74
Radiator - overheating 24
Rocker - three point 34
Saftey features 11
Sediment bowl gasket 10
Shifter boot 26
Spark plug wires 27
Spark plugs 7
Spindle - orintation 61
Starter - removal 36
Starter interlock 28
Stearing box - lubrication 31
Steering wheel removal 73
Strater bendix 52
Trouble shooting - tool for 50
Wiring harness - replace 42
Won't start - checklist 13
