753 bobcat skidloader
Anonymous-0
I need to replace the axle seals.
but i cant seem to get the hub off.
i have tried using a 10 ton porta power but it wont budge.
does any one have any sugestions?
thanks
After pulling the sprocket and chain off inside the gear case. Take off the wheel and knock it side ways and it might loosen up. sometimes they can be tough to get out.
Those 2 piece hub and axles some are tough, the axle shaft is tapered and also has a keyway. Heat and some as-good-as-possible licks on the backside from a sledge opposite the pressure from the porta-power should get it. Leave the bolt and washer in about halfway in the axle, when it turns loose it will jump off with some force.
