Oliver owner
- Location
- Maine
I had the head off my 77 for a valve grind. The previous owner had it overbored for pulling. I filled it with water today and it immediately started leaking out around the head gasket from behind the distributor to the back of the engine.
I torqued the head to 83 ft lbs following the pattern in the book. The old head bolt washers were all dished and cracked. Could they have just tightened the head until it stopped leaking? Is that even possible? It took quite a bit with a breaker bar to break them loose when I took it off. I then tightened the head to 95 ft lbs and still leaked. I then tightened it to 105 with no change.
I replaced the washers with grade 8.
