77 trans. input seal
Anonymous-0
Do you have to remove the belt pulley assembly to replace the trans. input oil seal or will it just pull out? I have the motor out and thought I would replace the leaking seal. Thanks , TC
Thanks for the reply. I took the pulley assembly of this afternoon . If I wasn't trying to keep the 77 original I would have probably have left the assembly off. Taking it off to replace a seal isn't fun. Thanks again, TC
remember that there is an O ring under the sleeve that the inbut shaft seal rides on that should be replaced also. they get old and hard from heat, my 2 cents worth.
