Another left firld question. I am looking at buying a 770. I had a fellow ( i think) tell me that the top linc set up high on them so as a disk mower wont work , is this correct? because that and brush hogging is what it will be used for
let er rip
bob
Post this on the Case board you"ll get more feedback. The older Eagle hitch case tractors did have the top link point up high and you either had to extend the equipment up to match or add a lower top link point (had to be creative). The later 30 series Comfort kings I think had 2 points and I would think the 70 series would have had only the 1 "normal" point or 2 as well. Best bet is to measure lower link points to top link point and lower links to PTO height. Can"t remember off hand what that distance is. Otherwise great tractors especially if its a diesel and it not a power shift. Power shifts were ok if not abused. Gaser"s weren"t bad either just not as good as a diesel. Good luck.
I grew up on a 770 Case. It has a standard three point hitch, catagory two, that will hook up to anything. We"ve run everything from John Deere mounted plows, mounted and semi mounted Bush Hogs, etc., etc. Ours was an 8 speed standard shift diesel. Pound for pound, HP for HP the absolute finest tractor ever made. Also had a 730 gas with the same three point hitch. Never had anything that wouldn"t hook up and work.
