Anonymous-0
I"m new to Oliver ownership, so please bear with me.....I have a 1964 770 rowcrop, and like it a lot so far....the power booster really works well for pulling gravity boxes. My question involves the power booster mechanism....if it goes bad, is it possible to operate without it? I"ve noticed the transmission is difficult or almost impossible to shift sometimes without pulling the PB lever back....so basically, if you decided to run without a working PB unit, you would have to keep it in low range (PB lever back)?? I ask this as I assume the repair to this unit, which appears similar to an IH torque-amplifier, would be quite expensive? Hopefully mine will not encounter problems for a long time, if ever, but thought I would be prepared if it does.....any thoughts?
