770 power steering
tbird
Putting full power steering on a 770. Using a char-lynn steering motor (In place of the saginaw used on late 770) and an oliver full power steering hydraulic cylinder. My question is, what would be the best choice for a pump to supply my oil? I prefer something readily available even if it means making my own brackets. Also, would the old style generator driven pump run this system?
Thanks for any help or advice
The full time power steering models used a small Cessna pump that has the relief valve build in. Do you have a 770 parts book that shows a picture of the unit? The mounting dimensions for those little pumps are kind of standard so other brands such as the Barnes would work. You would need a seperate relief valve and of course a seperate relief valve. Have you checked any of the salvage yards for parts? More questions? J.
J. Yes I do have a parts book and I cannot find a Cessna. I would however like the Cessna pump number (not the Oliver part number)and go that route if possible. As far as a barnes pump, I have no clue what to look for. Would the older generator driven pump work? I have a rebuilt one on the shelf along with the generator. Im just questioning its capability. Also, would I need a priority valve for it?
337-852-1703. please leave message with phone number as I am away from my phone for a few days.
I used a pump off a 69 Mopar car.Made a adjustable bracket that fit over the water thermastate inlet.Used a long belt to run all three pulleys.
I am knocking down a 770 that has the complete hyrastatic power steering. motor, pump, front cylinder. this was a factory kit from oliver, this is from an old oliver dealer.
