770 rebuilt cylinder head
valley green
I"m either going to have my head rebuilt on my 770 or buy a rebuilt head. Is there any vendor that you would recommend if a person were to buy a rebuilt head. Price and reliability are important. Mine has a couple burnt valves and I would rather just go ahead and do it as it"s never been done to my knowledge. Any recommendations would help greatly.
I would take it to a good machine shop and have them do it. Have them surface it if needed, put in hardened seats, probably guides as well and grind and lap the valves. Around here it will run about $250 if I remember the last time I had someone else rebuild a head for me.
Geoffrey
I have seen some rebuilt heads and I would pass on them. FYI, I don't know the age of your 770 but later ones had some changes made to the valves in the design of the keepers. Your 770 came equipped with hardened exhaust seats. I would get the springs checked and also the rotators. I would also use a good shop that does some industrial engines. If this is a diesel and an older one get a full set of seats installed and have the intake valves set to the correct recession and then set the stem height for the exhaust valves to the same specs. Questions?
If you get a head rebuilt wouldn't all the internals be new anyway? Sorry, it's been a long time since I had to have engine work done. It's a 59 gasser. I would expect for the price that all the moving internal parts would be new and the surfaces checked. What does a basic rebuilt consist of? Thanks.
A basic rebuild will be bringing all the old parts up to new SPECS. They will clean and reuse all the old parts they can, possibly just be grinding the valves and seats, checking (or replacing) the valve guides and spring pressures and making sure the base of the head is straight. (or flat)
Whatever parts needed will be extra.
Have you priced new parts for your 770? If a lot of new parts are needed the price will exponentially rise.
Talk to your machine shop operator and get a feel for what your 770 head needs.
Ask 5 different shops and you probably get 4 different prices and 4 different answers on what they do to rebuild a head.
