I have had experience using the 8 volt battery, the trick is to adjust the regulator as stated above, that way your 8 volt stays completely charged up to 8 volts, otherwise you just have a 6 volt battery in an 8volt case.
Problem is your points will start needing to be replaced more often, so you have to use a 2 volt resistor, this helps the engine turn over much better in very cold weather.
But what I have since learned, first, rebuild your starter & generator, new brushes, bendix & bearings make a big difference, give the engine a major tune up, using autolite plugs and the correct condenser (very important), not a place to skimp on buying quality products, time the distributor and set the dwell.
Replace both the battery cables with double ought "oo" size cables, the force turning the starter is AMPS not volts, the larger copper cables provide less resistance which puts the amps directly from your battery to your starter. Clean all electrical contact points to bare shiny metal, including lights & switches, bad connections rob your system of amps, lights will burn much brighter, then coat all connections with di-electric grease prior to assembly. Shop around for the highest cranking amp 6 volt battery that will fit in your tractor, the best ones now are gel filled, for a restored tractor there are no battery acid fumes peeling your paint or rusting out the battery box, any battery around 275 to 300 cranking amps should suffice, the colder the climate, the higher cranking amps you will need, also changing the engine oil to a lighter viscosity during winter months will also help cold starting.
I have a 55 farmall 300 that would barely start with an 8 volt battery, they would only last about a year without the voltage regulator adjustment, I got the regulator right and then started burning up points right & left, after two years of this I decided to do the things I listed above, replaced the cables, rebuild the starter & generator, new regulator, major tune up including valve adjustment, cleaned the rust out of the gas tank, & last winter, with a tractor supply 6 volt battery, she started in 19 degree weather on about the third turn of the engine with the choke pulled all the way out. If it is in tune & adjusted, it should start on the third or fourth turn of the engine each time, no matter what the temperature, that's the secret to a six volt system.
