8 volt batteries
badman
has anyone ever used an 8 volt battery on an 8n?
i have a 48 8n with a 6 volt system that i need to buy a battery for i do not want to switch it to 12 volts and i have been told that the 6 volt system will charge the 8 volt battery and that it will start better any suggestions ???
Why would you want to do that?
If you are having trouble starting the tractor, clean all the grounds & replace the battery cables. And make sure the battery is good & fully charged. (see tip # 49).
Now I'm sure we will hear from folks who are using 8v batteries w/ no problems & some of them may even have an 8v in an 8N. That's not unheard of by any means because some tractors are more easily modified to 8v batteries than others due to v/r considerations….......but why bother? If you tweak the v/r to charge an 8v battery, you need 9.4v. And, as JMOR said, tweaking a v/r isn't all that hard as long as you are prepared for the consequences of failure: a boiled battery, burned up v/r or no charge at all.
Here is a classic example of fixing the problem instead of band-aiding a solution:
From a post on 12/31/07:
“My starter motor quit turning the engine over. There was no click or anything on my 1947 2N.
I could hand crank the engine fine.
I got some new battery cables and cable to the starter which fixed it.
It really cranks up well now. I've got the original 6v system, and with the new cables it cranks up like it did when I had to jump it from a 12v back when I picked up the tractor from my grandfather earlier this summer.
It starts up immediately. Previously it had the original 1947 cables, which upon inspection had the inner strand wires corroded/severed.
Some of you guys thinking of doing a 12V conversion, if you don't need the 12V for some other electronics, might just need replacement battery cables.”
And a more recent quote from a post on 6/17/09:
“I used to have to jump my 6 volt 8N all the time....got a beefed up 6 volt battery, cleaned all connections and put in a new ballast resisitor and now it starts almost before one turn of the engine so it can be done with the exisiting system.”
50 Tips
8 volt battery is a band aid fix for other problems and in the long run causes more problem then it is worth. #1 a 6 volt system will never keep a 8 volt battery up to 100% maybe 7.5 volts max. #2 it is hard on the coil and lights if you have lights. #3 when was the last time you saw a battery charger that had an 8 volt setting on it. So again you either have a battery that you have to under charge or over charge since you can not charge it to a true 8 volts
IM NOT GOING TO THE 8 VOLT I SEE NO REASON TO SINCE THERE ISNT ANYTHING WRONG WITH THE TRACTOR BESIDES A DEAD BATTERY, IT WAS A SUGGESTION FROM A FREIND. HE HAD SEEN IT DONE AND THOUGHT IT MIGHT HELP THE COLD WEATHER SLOW CRANKS. I HAD JUST WONDERED IF THERE WERE ANY ADVANTAGES TO IT BEFORE I PURCHASED A BATTERY
Remember...this engine will start with an handcrank...it does not need to turn fast to start with a 6 volt battery. If it does not start with 6V battery there is a defective component then repair is required. 8V batteries were invented to burn generators, light bulbs, coils and your wallet..
ForDillac
