Anonymous-0
I have a 801 ford with select o speed transmission. I had this problem on this site befor but have more information and need more help. my problem is i cannot get the starter to turn over. first notice the wiring and the key switch was getting hot with key off. when trying to start solenoid would not click. So far I have replaced the key switch starter button light switch and traced the wiring down and repaced bad wires and done continuity checks. Have follow tests in service manual but my mechanic ability is not the greatest so may not be accurate. hooked up starter direct turn engine slowly, took plugs out like book said did turn faster. I would be happy if I could even get the solenoid to click or get it to turn over with the key. my concern is with the wires getting hot and the solenoid not clicking. also could the safty started switch in the transmission be the problem and how do you test it. also could the starter have a short causing the wire heating problem maybe i need to take it in and have it checked. any suggestion would be appreciated.
