Thor Wicklund
I have a couple questions regarding the mounting of a used 18.4-34 tire and rim on my 806. I took the old tire and rim off and left
the hub on the axle. The used tire/rim came with a hub on it as well, but I need to turn the rim around as it was off the other
side. The new/used tire and rim has fluid in it. I have a skid steer and several guys to help me.
1. I am assuming I should remove the hub off the new tire and rim and mount it onto the existing hub and mount it with the 12 wedges
vs flipping the hub around and trying to mount the whole assembly on the axle?
2. The rim has 4 notches on it, where does these go if I mount it on the old hub already on the tractor?
3. The new setup only had 6 wedges holding rim on the hub, the old hub had 12 wedges. When I set them together, they are different.
I have read there are are a few that are different, how do you tell? I have attached a few pictures. Thanks
![cvphoto55445.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto55445.jpg)
![cvphoto55446.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto55446.jpg)
