806 front axel
L.Williams
i have already broke a 24" pipe wrench with 4 ft bar on it trying to lossen up axel to adjust in, have put diesel and autotrans fluid mix on it now have a 6 ton bottle jack pushing out from frame to knee for 3 days with no results. what can i do that i haven"t already tried ?
Around here we lube them up good like you already have, loosen the clamp but leave the pin in and use it. Keep on lubing and at some point it will come loose, just make sure you catch it before you wreck the pin and holes. If your in a hurry then I don't have a good solution.
Casey in SD
Before you resort to a lot of heat, which is usually next step, beat the heck out of it all around the tube as this will loosen the rust. Maybe pray a little also instead of the usual language these front axles seem to bring out of a guy.
Did my 966 last year, grabbed one side and it slid right out, the other side needed a LOT of heat and a fairly severe beating!
