rustred
i got back to this 806. i checked more pressures. at 1200 rpm i have 20 lube pressure, operating is 205 steering is 250. when i dead end the steering wheel each direction i have 1700 psi. the torque lever in high is 250 in the middle its 240 maybe slight decrease when shifting to low, which is 250 psi. also dump valve is working builds psi just before tractor goes to move. brakes work good and push back at you when stepped on. all i am concerned about is when the oil gets hot the lube drops to 4 psi. so just want to know what is this lube psi oiling? and is it ok to use it as is at 4 psi? and yes the filter is new and clean. looking for 2 answers.
