820 crank seal
Popnascar
Anyone got a suggestion for seal crank at the flywheel on an 820. It appears to not have a seal. Where could I get the packing that is in behind (round this gasket type)
Pop- I"m no expert, but it was my understanding that there is no seal there, just the slinger. Under normal circumstances, oil will not leak, since the crankcase is vented enough to not force oil out. When I bought my 820, the morons who converted it from pony to electric start plugged off the crank vent, so it was definately blowing oil out the crank slinger, as well as anywhere else it could find. I fixed the vent, and I have a very nice starting tractor with no leaks, after all the oil in the exhaust was burned out. What problem are you having? or are you just concerned that you found no seal there? Kevin
