Hotflashjr
- Location
- Western MA
Anyone looking to hook up this OPS wiring harness - there are three connections in the battery box to be made which are not clear in the instructions. There is a yellow to yellow connection which brings switched power into the relay. There is a black to black ground. There is a 3rd connection which requires the use of a splitter supplied in the kit. This is a black and red connector with 4 prongs. It splits into two red and black connectors. One of those two connects to the harness to bring power up to the switch in the pod. This last connection was my issue because it appear from the factory this 4 pin connector had been electrical tape into the main harness wiring protector. With winch wiring in that box it was very hard to figure this out!
Also the relay is a 5 prong or pin even though there are only 4 wires going into the harness at that point. That is OK.
