I made adjustments on hydraulics on position and constant draft on lift cover in past. Position lifts fine but it will not lift in constant draft.
I am going to adjust them again.
My question is this. I procedure in my FO-20 manual but I watched a video of someone making adjustments on a NAA
Ford. He used a half inch rod thru both lift arm pins and on top of draft spring and uses 3/16 draft and 1/4 inch on clearance on control valve. Will this work on my 860. It seams easier than the manual in setting position of control arms.
I did not have control arms an lift control lever set right the first time.
Thanks.
Thanks.
